HELP! 305 tpi running badly
Old Feb 28, 2010 | 12:37 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
hi
my 305 tpi in my 85 t/a is running poorly, i replaced the ignition module twice, and esc module but now its just as bad if not worse. its running really rough the whole car shakes my rearview mirror actually fell off of the window, the exhaust is smoking grayish blue and smells not unlike oil. i know my head gasket leaks and my thermostat is bad(unrelated).
i will appreciate any help
btw power is seriously depleated in gear, i barely got it home backfiring and sputtering the whole way
Old Feb 28, 2010 | 01:23 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
Re: HELP! 305 tpi running badly
have you had the battery off???
Old Feb 28, 2010 | 02:11 PM
thetaman85's Avatar
i disconnected the negative battery cable when i replaced the ignition module
p.s. i found the plug wires were in the wrong order, i corrected that but it still runs rough and dies at idle in gear and its still smoking
Old Feb 28, 2010 | 02:41 PM
Car: 89 gta
i would say (no 100% but) the computer has lost your driving style if you drive her about 80mph for about 10 minutes she should sort her self out.
tpi computers great in the long run s**t if the battery comes of
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
