timing an l98
Old Mar 1, 2010 | 01:00 PM
my88iroc350's Avatar
timing an l98
im sure this has been posted a million times but i can not find it but can someone please tell me the proper procedure to timing an l98 i have a timing light an everything to do it pictures would be very helpful because im a very visual person
Old Mar 1, 2010 | 01:04 PM
Drew's Avatar
Re: timing an l98
Drive the car long enough to reach operating temp. Disconnect the EST (tan wire/black stripe, single connector near the A/C box), loosen the distributor hold down bolt. Start the engine, set the timing to spec or your desired setting, tighten the clamp and check timing again. Turn car off, reconnect EST, disconnect battery cable for a few minutes to clear the codes, then reconnect and test drive.
Old Mar 1, 2010 | 01:21 PM
Re: timing an l98
ok is the est near the ac or brake booster ive been told both i need a definate answer
Old Mar 1, 2010 | 01:56 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: timing an l98
Near the ac box, a single tan wire with a weatherpac conn on it, it breaks out of the large wire loom.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
