coolent lines
Old Mar 8, 2010 | 02:34 PM
yamaha6611's Avatar
coolent lines
okay guys i am wondering.. where is the return spot for the coolent line that comes off the water pump??? i want to block it off but for now i may just run it, i know it goes up into the throttle body/intake mani and then out the other side, then into the heater core and thru the oil cooler, but where does it come back into the rad?!? it doesnt make any sense to me...my plan is to just plug the port coming out of the waterpump housing and ONLY run an upper/lower rad hose...best i can make lol
Old Mar 8, 2010 | 04:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: coolent lines
Coolant goes into the waterpump ;it is the "return (suction) line"
You need to plug the outlet ( supply ) fitting on the intake as well
Old Mar 8, 2010 | 05:35 PM
yamaha6611's Avatar
Re: coolent lines
ah okay cool thats what i was hoping for, so the other line is also what needs plugged... which is the line thats directly above it??
Old Mar 8, 2010 | 08:17 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: coolent lines
you've got it all wrong buddy. It goes like this. From the upper driverside radiator to the intake manifold, intake manifold of course to the block, pump and right into the bottom passengerside of the radiator. The secondary route. from the front of the intake to the bottom of the throttlebody. From the passengerside of throttlebody to the heater core. From the heatercore to the small male fitting on the upper passenger side of the radiator. As for the oilcooler, I dont know for sure. If you wnat to eliminate the throttlebody section from recieving radiator fluid, there is a spot here in the "tech forum" in the home page.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
