Aftermarket TPS
Old Mar 10, 2010 | 08:44 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Aftermarket TPS
Has anyone tried any of the aftermarket tps? The voltage on mine jumps around a bit so I've been thinking of replacing it. I can't seem to find an OEM replacement (haven't checked a GM dealer yet) but I'm curious about the other ones that are out there. Most of the auto parts stores cary one made by BWD. Napa has one made by Delphi and one made by Echlin. There is a significant range in price so I'm curious what the deal is. Are these junk or do they actually work? Thanks in advance.
Old Mar 10, 2010 | 08:50 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Aftermarket TPS
echlin has pretty good quality replacement parts..
Delphi Is a OEM part.. I would purchase the Delhi,, or call your local GM dealer they should be close in price...
Old Mar 10, 2010 | 09:24 AM
Car: 1988 GTA
Re: Aftermarket TPS
Ok thanks for the info. I didn't realize that Delphi was OEM. Has anyone tried the BWD tps? That one is the cheapest, around $30 bucks. I just don't want to waste my money if they are junk.
Old Mar 10, 2010 | 06:23 PM
Guest
Guest
Posts: n/a
Re: Aftermarket TPS
Thats what is in my car, the BWD.
Old Mar 11, 2010 | 07:00 AM
Car: 1988 GTA
Re: Aftermarket TPS
Any downsides vs. the stock tps?
Old Mar 11, 2010 | 08:54 AM
Guest
Guest
Posts: n/a
Re: Aftermarket TPS
Not that I know of. Its a pretty simple device, not much to it. Had mine in the car for more years than I can remember.
Old Mar 11, 2010 | 09:22 AM
Car: 1988 GTA
Re: Aftermarket TPS
Thanks for the input. I'll most likely end going with the BWD then. I can't see paying an extra $40 if the BWD works just as well.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
racereese
Oct 3, 2015 03:46 PM
