injector question
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
injector question
I recently bought a set of design III Ford 24 lb. injectors to replace my design II's, but the design III's do not have a groove in them for the locking ring to lock them onto the fuel rail. Are these the wrong injectors??? The plugs are the same and they are the same length and everything.
Any help would be apreciated as I want to make sure I do this right.
Re: injector question
I just replace mine in my 89 5.7 with bosch III. no clips. Mine were a 1/4 shorter than the multecs. If yours are the same make sure they are seated in the intake manifold. check for leaks after you get the fuel rail back together. Im glad I did.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
No bro. I got em too. They just are suspended in there. Not a big issue but before you put on your upper intake, prime the fuel system to make sure that there are no leaks.
www.southbayfuelinjectors.com
If you purchase bosch lll injectors that are shorter than the multecs, just add a second oring to the bottom of the injector or send them to us and we will apply our new adapter to the bottom of the injector making them plug and play.... at no charge to you!
Installation can be a little strange the first time though, I think it worked best for me to seat the injectors all the way into the intake, then guide them into the fuel rail. Otherwise they try to push up into the fuel rail too far.
Yeah, I guess by force of habbit I try to put things back together the way they come apart, that being into the rail first then the intake. But without the factory clips, it is difficult that way, much easier to put them into the intake first. I usually get there eventually.
I had no problems putting them in with them installed into the fuel rail. I did have one problem though, a sore and tired lower back.
Engine: 355
Transmission: 4L60
Thanks for all the input guys. Mine look to be of proper length, so I don't think they need anything, but thank you for the very generous offer southbay.
Now....if I can just figure out how to get this superram together and plug the injectors in once it is.
This is the most challenging intake I've ever dealt with, thats for sure.
This is the most challenging intake I've ever dealt with, thats for sure. Joined: May 2009
This is the most challenging intake I've ever dealt with, thats for sure.our pleasure!! If we can help in any way just give us a call.
It sure would have been alot easier to change the injectors when the engine was still on the stand about a week ago. Live and learn.
.. The job has got to get done and when desperate measures arise, you must attack by any means. Good deal bro. Peace. Thread
Thats too much bro. I feel your pain. What did you use? A step stool?
