Superram clearance issues
Old Mar 11, 2010 | 05:52 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
I am having issues with the plenum on my superram. It doesn't have enough clearance at the windshield wiper motor on my 91 GTA to bolt up to the runners. Does anybody have a solution for this?
Old Mar 11, 2010 | 06:43 PM
1970 Buick's Avatar
Car: 1989 GTA
Re: Superram clearance issues
Hey, if you check out the alternative intake section, i.e. HSR SR MR, there are a TON of threads about the SR and their issues. I believe many people have tackled this very problem and had success with it.
Old Mar 11, 2010 | 07:29 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Here's what people don't know about their cars, the K-Member has a lot to do with how headers and the Super Ram fits. Some cars like mine, the K-member sits about 1/4 in to the left. In the Camaros you can tell 2 ways. 1st have you ever notice that the left front tire sits more inside the fender well than the right? If they are the same distance, you may have problems installing SR's and SLP Headers. 2nd have you ever notice that the throttle body to the snorkel are not straight in line? These are the main reason that some people have these problems.
If your motor mounts are sagging, this is one of your problems. If you install a poly transmission mount it will raise the trans about 1/4in an at the same time raise the back of the engine. This will give you the clearance you need.
Old Mar 12, 2010 | 01:56 AM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
Are you serious about the 1/4 offset? is that from factory?I thought my car at one point was possibly wrapped around a tree lol.
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
