Will stock Airfilter system work with Throttlebody upgrade?
Old Mar 21, 2010 | 07:00 AM
68 RS/SS Ragtop's Avatar
Car: 68 RS/SS cnvrt, 92 Z28, 02Blkbrd
Engine: 295hp 350, 385hp 350, 420hp LS1
Transmission: 4spd, 700r4, T56
Axle/Gears: 3.11, 3.23, 3.42
My car looks completely stock under the hood and I want to upgrade my throttlebody to a 58mm one. Will the stock rubber bellows tube connecting my airfilter system to the throttlebody still work?
I'm looking to go with this throttlebody : http://tpiparts.net/inc/sdetail/8042
Thanks for any information you can provide.
Last edited by 68 RS/SS Ragtop; Mar 21, 2010 at 07:01 AM. Reason: can't spell for crap
Old Mar 21, 2010 | 07:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Will stock Airfilter system work with Throttlebody upgrade?
I couldn't get mine to fit over the tb opening.
Old Mar 21, 2010 | 07:40 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
why do you want to upgrade to a 58mm throttle body? You will probably gain nothing from it. Its only needed if your making close to 500 hp or more. I myself run a 52 mm and is plenty for my application. If I were you, I would keep the 48mm on and spend my money elsewhere. Like a nice set of headers. They are one of the best bang for the buck on our cars.
Old Mar 21, 2010 | 08:13 AM
Thank you for the input. I guess a little background info would have helped. Car has Fastburn 385 350ci (hotcam/1.6 rocker) motor with headers (the headers being the only thing that doesn't look stock under the hood.) Fastburn heads have Scoggin Dickie high flow baseplate. I'm working backwards from the engine as my $$ provide for upgrades. Currently have amassed ported-internally polished plenum and TPIS large tube runners. I'm looking for highest flowing- stock looking- throttlebody that will accomodate the stock rubber bellows. I'll be finishing it up with 24# injectors and a tune.
It really leaves those SRT-4 boys scratching there heads when I open the hood and tell'em it's an L98 with headers
Thanks again for any info.
Old Mar 22, 2010 | 07:05 AM
So, does any one have a 52 or 54 mm set up with a stock bellows connecting the air filters?
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
stalkier
Aug 7, 2015 04:49 AM
