Throttle Body Holes
Old Mar 22, 2010 | 07:20 PM
nevrdun's Avatar
Throttle Body Holes
I'm in the process of building a new plenem for my TPI and I've run into a problem. I need a print of hole sizes and locations for the front of the plenem where the throttle body bolts on. For example, what is the location of the mounting holes in relation to the throttle holes. I've checked three different throttle bodies and all seem to be different by about .010-.015. So I figured I try to find out what Chevy machines them at. I did some searching but can't seem to find anything. Anybody got ideas??
Old Mar 22, 2010 | 08:58 PM
Damon's Avatar
Re: Throttle Body Holes
Doubt you'll find the exact info, but I'm not too surprised that there is some variance between different units. The stock plenum has inlet holes that are a fair bit bigger than the 48mm bores of a stock throttle body. They're about as big as an aftermarket 52mm unit. So I'm not sure it's a dimension where .010" makes much of a difference.
I'd just use whatever your chosen TB is as a template and go from there.
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
