Intake advice Please
Old Mar 24, 2010 | 07:27 PM
Hesstrck26's Avatar
Car: 1988 iroc z hard top/04 fast cummin
Engine: 5.7 350
Transmission: built 700r4
Axle/Gears: 2.77
Just ran a tb coolant by pass and put new iac and tpis iac housing on to clean it up a little(and fix idle problem), and noticed i have a coolant leak on driver side front intake (coming from the tstat too). It is auctually pooling a little until run then burns off.
So my question is which aftermarket intake (hsr, miniram, big mouth, etc)) will be easiest to replace with. If i got to fix the leak might as well replace the intake. The car is an 88 5.7 tpi w/ 44,000 miles completley un molested accept for tpis afpr(@ 47psi), 52mm holley tb, msd blaster coil, udpulleys,a built 700r4 w 2400 stall, and a burned chip from tpis.
ALL experienced advice would be great. As I mainly have worked on and built cummins (fastest 11.97 @109) and this is my first try with efi, and I bought the car 3 years ago and havent done much w/ it until now.
Old Mar 25, 2010 | 12:34 AM
Hesstrck26's Avatar
Engine: 5.7 350
Axle/Gears: 2.77
Re: Intake advice Please
what im asking is which intake will work with stock heads and requires least amt of modification
Old Mar 29, 2010 | 04:36 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Edelbrock HI-FLO runners and base. I have a set if your interested.
hydrolic144
Oct 4, 2015 08:23 PM
dutch930
Sep 11, 2015 06:58 AM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
djmarch
Aug 19, 2015 12:07 PM
