Correct injector size
Old Mar 25, 2010 | 08:06 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I need to replace my leaking stock injectors soon but I need to make sure I get the correct size. I've got a 305 tpi which uses 19lb. injectors. I've been looking at the bosch design III injectors and I've searched the forum several times but I still have a question. Are the 19lb bosch III's the correct size for my engine at the stock fuel pressure setting of 43.5 psi? I can't seem to find anywhere where it says at what fuel pressure these injectors flow 19lb./hr. Since newer systems run closer to 50 psi I just want to make sure these are the correct injectors. Can anyone confirm? Thanks.
Old Mar 25, 2010 | 09:02 AM
southbay08's Avatar
Re: Correct injector size
Yes you need 19lb injectors for a 305. We have the 19lb Bosch lll, they are 19lb @ 43.5psi. they will be just fine for your car. you can pm or call us at 516-492-6504
www.southbayfuelinjectors.com
Old Mar 26, 2010 | 08:13 PM
stampede52's Avatar
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
