heads ?
Old Mar 26, 2010 | 09:22 AM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
heads ?
i want 64cc heads on my 92 camaro. my question is can i put pre 86 heads under my tpi? say like camel back heads. i just dont remember what year the intake bolt pattern changes.
ALSO DOES ANYONE KNOW WHAT HEADS ARE ON THE STOCK LB9 AND WHAT CC THEY ARE.
THANKS.
Old Mar 26, 2010 | 09:56 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
Re: heads ?
I believe the heads changed the two center bolts on either side of the intake mount in '88 . You cant use 046 or 461x type heads cause of lack of accessory holes .Your stock Alum. heads are great heads with some pocket porting and port matching. do that and a steady diet of mustangs and Hondas
Old Mar 26, 2010 | 10:31 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: heads ?
THANKS.
Yes you can use them, but the center bolt-holes on the intake manifold have to be modified, and you may have to drill & tap accessory holes.
LB9 is the 5.0L with iron heads. 416 castings are common LB9 heads and they have 58cc combustion chamber, and 158cc intake port volumes.
You could get the chamber volume you want from your stock heads by deshrouding the chambers and/or using different valves. Using a thicker headgasket will also increase the virtual chamber volume. I just don't understand why you'd want to do that if you are running fine with the stock 58cc chamber volume.
Old Mar 26, 2010 | 10:56 PM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
Re: heads ?
well i was talking to someone about a 305 and they said do a flat top piston with 64cc heads and u will be happy. do u think the heads that are on it will do better?
Old Mar 28, 2010 | 12:58 AM
F-Body Demon's Avatar
Re: heads ?
https://www.thirdgen.org/forums/tech...w-numbers.html
That's 10 cfm off Vortec heads...and the best part is you already own these ones.
Old Mar 28, 2010 | 02:16 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: heads ?
Unless you have a really good specific reason to do so, increasing chamber volume is a bad move.
Maybe that person was confused, or the message got confused.
Increasing air-flow through the head is the way to increase performance.
Reducing chamber volume increases compression and power/efficiency to a certain point - as much as the engine can handle on pump-gas.
You should do a lot more research before planning a cylinder head change or modification.
IMO, for a 305, the best budget upgrade you can do to your factory heads is a DIY porting job, along with a valve upgrade/conversion, with machine work and reconditioning done by a reputable head/machine shop.
Information about a budget LSX valve conversion can be found in two links in my signature.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
