MAF Problems?
Old Mar 30, 2010 | 09:49 AM
2c2g's Avatar
Car: 88 trans am
Engine: 305 tpi
MAF Problems?
I'm having the same problem with my 88 305 .Its really had to keep it running when it cold if i keep the maf hooked up, I've checked the cold start injector and it's spraying at start up. i adjusted the tps to 0.5v at idle position and 4.9 at wot, the Iac vavle is set to 1-1/8" The 8 injectors all read about 16.7 to 17 on the ohm meter,I haven't checked if the injectors are bleeding down with a fuel pressure gage because i don't have one. I don't smell alot of gas when it does start. Its seem like it's running out of gas.It will run for about 5-7 secons at 1100 rpm then dies.If I keep pumping the throttle to keep running until it warms up it's fine but that takes about 4-5 minutes to do that. Should i check the regulator and how would i do that? Any sugggestions would be greatly appreciated.
Old Mar 30, 2010 | 03:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I moved this to its own thread, because the LT1 thread you posted in isn't the right place for your question.
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
