zz4 or comp cam thumper
Old Mar 30, 2010 | 06:03 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi !! if i can make a chip to run a 107 lsa cam , so what will be the best choice a zz4 208:221 .050 in duration with .474 int .510 ext 112 lsa or comp cam thumper 08-600-8 227:241 duration .050 in .518 int .503 ext 107 lsa both 1.5 rocker ratio lift this is for a 383 strocker with fully ported alluminium corvette heads with hsr intake ...
Old Mar 30, 2010 | 06:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: zz4 or comp cam thumper
Originally Posted by camaro350tpi
if i can make a chip to run a 107.lsa cam ,.
107... Big IF
Do a search , the Thumper cams don't get a good review because they mostly make your engine " sound " lumpy because of the big overlap
There are better cam choices for a 383 out there .Look at the many online 383 builds and see what cam they used.
Why try to reinvent the wheel?
Old Mar 30, 2010 | 08:25 PM
i know theres always better but right now ive got both of these cam in my hands so for now i dont want to by another cam if you think thumper cam is better tant z4 cam ill go for it
Old Apr 2, 2010 | 01:02 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
with the thumper cam your going to get more power and sound obviously but your going to have a lot of "fun" tuning for that...
the zz4 cam you wont have hardly any trouble tuning for and will still net you a good amount of extra power.. Personaly, I would go with the zz4
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
