Which TPI Runners?
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Which TPI Runners?
Hey everyone, Im new to this TPI system and Im trying to get an idea of what would be the best route for me. I did a search and not much related to exactly what Im asking.
I thought a bit ago that the HSR was the best choice but after doing some research Ive come to the conclusion I want to go a different route.
I would like to keep my stock plenum and fuel rails if possible.
I plan on getting 24lb injectors and a adjustable fuel pressure regulator.
I dont plan on being cheap in this endeavor, but Im not rich at the same time.
That in mind, My questions are:
-is the edelbrock runners and baseplate and good deal? do they work with the stock plenum? do I even need the baseplate?
-is a high flow baseplate worth it or is runners where its at, if so what runners are the best?
-what would I have to do with the stock plenum?
Any comments or opinions are appreciated!
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Which TPI Runners?
Bigger injectors with stock internals won't do much more than I would say increase your fuel consumption... your stock 22 lb injectors should be fine... there's an intake I think called mini-ram that a number of members are happy with... personally I would rather go with Edelbrock...
https://www.thirdgen.org/forums/afte...-mini-ram.html
Engine: 5.1 4bbl
I noticed that the article you provided said that the Edelbrock High Flow TPI system is designed for 85-91 cars. Why not 1992? So that system won't work on my 92 z28?
What are your guys thoughts on this manifold?
http://www.tpis.com/parts/view/32
Sorry to thread jack, but I'm looking at doing the same thing and a lot of people get mad when the same questions keeping asked.
Car: 1989 GTA
If your going to go with aftermarket runners then you should get an aftermarket base. If staying stock is what your after then the edelbrocks will look very out of place. AS&M and Accel make runners that look very similar to stock ones, only larger internally. SLP makes a very good runner that can be megaported allowing tons of airflow. Your plenum will need to be ported to take advantage of the new runners too. Do a search, there are tons of threads and even "how to's". The best base I have seen is the old Accel Superram casting. TPIS has a Bigmouth base and Edelbrock's is supposed to be ok too. Good Luck.
Engine: 5.1 4bbl
85-88 had the cold start injector
89-92 did not have the cold start injector...
it should cover 92 TPI....
Car: 89 Trans am
The tpis big mouth system seems like a good bet, good low-mid end trq. Ill do alot more research but thanks alot for that link!
Engine: 5.1 4bbl
yes well my choices are limited because of emissions and the requirement of having a CARB EO decal... otherwise if I were to get pulled over I could face possible fines and getting my car impounded... a risk I really to feel I want to take...
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
there is a ton of stuff on here about it.Keep looking.Heres mt
Depends on how much money you wont to spend and if you want it to look stock.I bought another plenum to port for like $50.Bought a used tpis lower intake manifold for $250,and a set of slp runners for $200 i think.IIRC you get more gains out of the lower manifold than runners.Runners without manifold and/or ported plenum will prolly do very little.The slp runners do not look stock and dont flow supper awesome in stock casting but have a ton of room to port and improve,which i did.TPIS or edelbrock lower manifold will be the easiest to find and are all made by edelbrock now.You may find an old accel base however.
With stock heads and cam You may not see a ton of improvement but I do think you would see some improvement.IMHO,Look around and get some used stuff and save you some money.TPIS/AS&M RUNNERS FLOW GREAT AND LOOK STOCK BUT THEY ARE PRICEY and harder to find use it seems.The slps will flow as well with some work.The works not that hard,with the right tools and research.Edelbrock now makes all the different bases.A buddy of mine has an old accel base he was going to put on his brothers SR/406 cid but it didnt seem to fit the afrs he had as well as the tpis base did.
We have measured the old accel vs the tpis manifold and there is really no difference.Especially when you port like we did.
Btw the miniram and hsr are better but are atleast twice as expensive.
Depends on how much money you wont to spend and if you want it to look stock.I bought another plenum to port for like $50.Bought a used tpis lower intake manifold for $250,and a set of slp runners for $200 i think.IIRC you get more gains out of the lower manifold than runners.Runners without manifold and/or ported plenum will prolly do very little.The slp runners do not look stock and dont flow supper awesome in stock casting but have a ton of room to port and improve,which i did.TPIS or edelbrock lower manifold will be the easiest to find and are all made by edelbrock now.You may find an old accel base however.With stock heads and cam You may not see a ton of improvement but I do think you would see some improvement.IMHO,Look around and get some used stuff and save you some money.TPIS/AS&M RUNNERS FLOW GREAT AND LOOK STOCK BUT THEY ARE PRICEY and harder to find use it seems.The slps will flow as well with some work.The works not that hard,with the right tools and research.Edelbrock now makes all the different bases.A buddy of mine has an old accel base he was going to put on his brothers SR/406 cid but it didnt seem to fit the afrs he had as well as the tpis base did.
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
i have just fitted an edlebrock inlete manifold. OMG!!!!!! after a couple of years of running edlebrock heads and bigger cam, then about a year with slp runners and bigger tb, i decided to chande the intake. i can honestly say that other than using nitrous, its the biggest power gain ive ever noticed. its like the new manifold has somehow awoken the heads/cam/runners!
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Will
Transmission: Pro-built 700R4
2) Why would a cop look under your hood? And how is he going to know which equipment requires E.O. numbers? I've never been asked to pop my hood, and I have been pulled over many, many times.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Engine: 350 tpi
i literally just put the new manifold on. im even using the stock 22lb injectors. my best quater mile time before hand was a 13.2 @ 102 mph. it really does feel like it could do a 12.9 now, it feels so much more powerful. i also installed a ram air hood and acompaning air filter box too.
Sanjay
Aug 12, 2015 03:41 PM
