Low MAP Voltage (code 33)
Old Apr 3, 2010 | 10:53 AM
Randy_M's Avatar
Car: '92 RS Camaro
Engine: '92 SD 305 TPI
Transmission: BW 5 speed
Axle/Gears: Stock Open 3.08:1
I have a '90 Corvette speed density TPI system in an older car. It has run almost perfect until very recently when I began getting a code 33. My information says this is "low voltage at the MAP sensor". When the trouble light comes on with this code, the car will run rough near idle for a few seconds but with any following acceleration the light goes off and the car seems to accelerate OK. This may not happen again for a few minutes (mostly in town traffic) but seems to come and go. I have changed the MAP sensor, the vacuum tube between the MAP sensor and the plenum along with trying a second computer. None of these changes appear to make any difference. Anyone have any ideas/suggestions?
Old Aug 15, 2011 | 10:04 AM
phidoe2000's Avatar
Re: Low MAP Voltage (code 33)
Did you ever figure this out? I've had the same problem. Replaced MAP sensor and connector. Did not fix it, though.
Ken
Old Aug 15, 2011 | 10:34 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have had my share of code 33/34 problems (maf not map), mine ended up being the pigtail connecting to the maf, maybe give that a try.
GTAman
Mar 15, 2019 11:40 AM
Cornholio7979
Sep 20, 2018 02:31 AM
GTAman
Sep 21, 2015 09:57 AM
