gasoline evap canister
Old Apr 3, 2010 | 02:34 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
So i broke one of the feed lines into the evap canister. I was trying to move it closer to the radiator cause i was making my CAI and i broke of the nipples trying to take the hose off. Anyway to replace just the top? Do i really need this? Or whats a way i can costume make one and mount it somewhere else?
Old Apr 3, 2010 | 03:05 PM
3rdgenred's Avatar
Re: gasoline evap canister
Really need an input or opinions please? Ive read a lot of other threads on this item. I know you dont need it but its recommend to keep fuel evap pressure down as well as vent the fumes out of the engine bay. any input guys?
Old Apr 3, 2010 | 03:35 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
For california smog you need that canister you can try threading a brass hose nipple into it seal it with silicone i have fixed them that way before.
It doesn't have to be in that spot you can move it anywhere you wont just make the lines longer.
Old Apr 3, 2010 | 03:41 PM
3rdgenred's Avatar
I can see your point with the nipple. My question is will thy restrict the flow of the vapors into the canister. The actual diameter will now be smaller due to the size of the wall on the outside of the nipple.
Old Apr 3, 2010 | 03:48 PM
3rdgenred's Avatar
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Quzyle
Oct 15, 2015 03:35 PM
shanelique22
Sep 24, 2015 06:30 PM
reactor60
Sep 22, 2015 01:44 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
