where do i buy a replacement EGR pipe?
Old Apr 6, 2010 | 06:51 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
there is a trio of very small hoses running around and under the intake, on the passenger side and front. they all three connect in a splitter, and one runs underneath the throttle body, over to the drivers side. these hoses are really hard and brittle, and i snapped that one. now my car won't start. it's sat for quite a while but has always turned over for me (every month or two) after breaking this, i wasnt able to get it to start, but i didnt try that day before breaking it.
i looked through my service manual, and believe i found the hose i broke on page 6e3-c7-4, figure c7-8, identified as #6, egr diag temp switch. where do i find a replacement?
Old Apr 6, 2010 | 07:27 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: where do i buy a replacement EGR pipe?
You can pick up those hard plastic vacuum lines at any auto parts store. Its easiest just to bring in a broken piece of the old line to the store and then match it up with what you need.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
