305 TBI to TPI with 7730 ECU??
Old Apr 13, 2010 | 07:10 AM
jbucago's Avatar
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
So i have this 7730 ECU but im not sure if it is for 5.0 or 5.7 TPI
I have an 89 formula Firebird 5.0 TBI
i want to turn my TBI in to TPI
If i obtain a TPI system and wiring harness
Can i use this ECU if it is for 5.7 TPI or 5.0 TPI
I am still trying to obtain the :
Intake Manifold
Throttle Body
fuel rails
Wiring harness
Old Apr 15, 2010 | 06:03 PM
jbucago's Avatar
Re: 305 TBI to TPI with 7730 ECU??
was this like a stupid question or somthing...?
Old Apr 16, 2010 | 01:40 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
As far as I know the 1227730 ECU can be used for both 5.0 and 5.7 TPI. The only difference between them is the PROM inside the ECU.
Old Apr 16, 2010 | 04:20 PM
jbucago's Avatar
well if the prom waws for 5.7tpi could i use that on a 305 motor... if i just disconnected the o2 sensors?
Old Apr 17, 2010 | 12:52 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
First of all, if you disconnect the O2 sensor, then you won't be able to even take the first hundred meters with your car. So DO NOT disconnect the O2 sensor.
The 5.7 TPI PROM is not suitable for 5.0 TPI without modifications. This means if you want to use that ECU on a 5.0 TPI engine, you'll have to change the PROM because for example the injector sizes are different, and of course a few more parameters as well.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
