22 lb injectors?
Car: 1987 Formula
Transmission: 700 R4
Axle/Gears: 3.42 L/S
22 lb injectors?
I would like to bump my injectors up to 22lb from the 19lb stock. Is this as simple as it sounds or do i need to adjust or change other things to make it work correctly?
any help would be appreciated.
any help would be appreciated. Thread Starter
Car: 1987 Formula
Re: 22 lb injectors?
Ok i went back and read some previous posts on this and maybe i should just stick with the 19lb injectors. This site is phenominal with the amount of info you guys share. After reading just a few of these catagories i feel much better about my ability to keep my car up and running correctly.
thejimsterz28
Sep 15, 2015 04:37 PM
