? on a new motor build for my gta
Old Apr 17, 2010 | 01:21 AM
srshll's Avatar
I am going to run a 355 stock crank ,rods and forged flat top pistons with edelbrock heads and a lt4 hot cam with mac headers. for now. I am going to run the stock intake and injectors. Will this thing run at all before i get it tuned or no? Also does anyone do any chip burning or dyno work in Kansas city, Wichita,? Thanks Kevin
Old Apr 17, 2010 | 11:28 AM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Re: ? on a new motor build for my gta
I don't know if there is anyone in your area or not. If not you can try Brian at tbichips.com Its obviously better if you can find a dyno and do it locally. If you can get some better runners like AS&M's or TPI's big tubes or a set of SLP's and open them up, port the base as much as you can, port and siamese the plenum and you will do very well. I am planning a 350 with a LT4Hot cam, my excisiting TPI stuff and a set of the Pro Comp 190's. I would love to be in the 290 - 320 rwhp when I get done. I agree that you may have trouble getting the car to run without some tuning with that cam. Good Luck.
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 13, 2015 08:28 PM
NBrehm
Aug 5, 2015 07:57 PM
