Fuel Pressure
Old Apr 18, 2010 | 11:45 AM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Fuel Pressure
I have a 86 5.0 FI I jus put in a bbk fuel pump in and have had a bbk afpr for about 2 years i have started it already with the pump in before but now when i have tried to adjust the psi it doesn want to start only reading at about 20 psi kinda lost on how to get the psi to get back up got a half tank tried adjustin the screw but nothin jus at that 20 psi any help or suggestions i would appreciate thanks guys
Old Apr 19, 2010 | 01:28 PM
knight123's Avatar
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
Re: Fuel Pressure
assuming that the AFPR was already set before and your filter is clean then you probably have the wrong pump. 20 PSI max is what you would get out of a TBI fuel pump so if you are looking for 40PSI then it could be the case. I put in the wrong one and got 22PSI - everything else was good, took it out and got the correct one and 45PSI.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
