Fuel pressure regulator
Old May 5, 2010 | 11:15 PM
Hutts's Avatar
Car: 1989 gta-1995 formula
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3-45
Put an adjustable fuel pressure regulator on my 89 305 tpi just wondering what pressure i should set it for best performence thanks.
Old May 5, 2010 | 11:25 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Fuel pressure regulator
set it to stock pressure and adjust from there. bumping the fp up on anotherwise stock engine won't really do much for you. Adjust for your mods
Old May 6, 2010 | 12:02 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
any MODS
start @ 35 PSI
Old May 6, 2010 | 06:45 AM
Hutts's Avatar
Engine: 305 tpi
Axle/Gears: 3-45
just small mods exaust and intake also have slp runners, what is stock pressure, and should you check it running with vaccum hooked up also what happens if its set to high, thanks for help.
Old May 6, 2010 | 10:24 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You check it with the vacuum line disconnected, stock for your year is around 46-48. To really check to see if you have a good setting is at the track or on a dyno unless you really trust your butt dyno.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
