fuel rail, injector?
Old May 8, 2010 | 10:12 PM
bradsgtz's Avatar
im about to swap 305 tpi to 350tpi. so will the 22# injectors work on a 305 fuel rail. dumb question but tryin to get everything laid out for smooth sailing i hope. and i want the right injectors for the right motor. 19# only have a limit for their abilities. THANKS
Old May 9, 2010 | 01:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel rail, injector?
Everything on the TPI intake is the same; only the size of the injectors is different
Old May 9, 2010 | 09:09 AM
southbay08's Avatar
just make sure you have the proper length for the injector to fit, remember, stock injectors for tpi set ups are a little longer.
Make sure that you install them into the intake first! Otherwise they will not seat properly
www.southbayfuelinjectors.com
Old May 9, 2010 | 09:32 AM
bradsgtz's Avatar
thanks everybody, just wanted to make sure. and il be sure to hit up SB for the inectors
Old May 9, 2010 | 10:29 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
the injectors.. will not do to much!!! until you match your 305 PROM with 350 settings
Old May 9, 2010 | 06:25 PM
bradsgtz's Avatar
il be getting the ecu programed. and id also like to buy the burner kit to do it myself so I know what my car is tuned for. i have a friend that has a dyno so all that type of tuning will be easy
Old May 9, 2010 | 07:19 PM
88gta3508's Avatar
Engine: 231 / 383
Dyno will be nice to show you were your at..
tuning you need to learn what parameters to change.. like on my setup almost every parameter had to be cranked .. tunning yourself >>as I do is the only way
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
