TPIS big mouth intake gasket question
Old May 27, 2010 | 08:36 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Transmission: T-5 Tranny
Axle/Gears: 373
I just wanted to know about the gasket for this intake will the stock TPI gasket run the same or do I have to order a special gasket?
Old May 27, 2010 | 09:23 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: TPIS big mouth intake gasket question
It's been a few years since I got mine, but it seems to me that they sent gaskets with it. So if you order it, and if you've got time to wait 'til it arrives to see if gaskets are included, then don't order any gaskets yet because I think they'll be included.
Old May 27, 2010 | 09:36 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Axle/Gears: 373
Well that's a good point but I already have the intake, I had to remove the intake to remove the heads for some spring up grades for this ZZ4 cam swap I went with, but like I said I need to replace the old gasket but will the original TPI gasket work on this?
Old May 27, 2010 | 11:50 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
At most, you'll need to get out the x-acto knife and trim them a bit but stock ones will work.
Old May 28, 2010 | 10:35 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
TPIS hand ports the intake before shipping.
Just tell them what intake port size (1204, 1205, etc.) you are running.
Yes, gaskets are included.
Best Regards,
Bruce
Old May 28, 2010 | 11:17 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Base to head gaskets are included. However base to runner gaskets are not.
Stock gaskets will work, you just put them on and trim them with a rotary tool and sanding drum.
Very easy to do.
Old May 28, 2010 | 04:38 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Axle/Gears: 373
Yeah I've been aware of the runners, I've got a set of big mouth runners and I know I need to send off to get those gaskets because the stock runners gaskets won't work on them. Thanks I kind of though about just trimming the gaskets if I needed to but I just wanted to make sure hey by the way will the LT4 springs fit L98 heads? Dose anyone know? I need to make sure before I send for them this ZZ4 cam has a lift of .510, will these springs do?
http://paceperformance.com/index.asp...D&ProdID=24732
Here's the link
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
