TPI Intake Gaskets
Old May 27, 2010 | 10:02 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
TPI Intake Gaskets
Hey guys, as the name suggests I need to know where to get some TPI Gaskets. I have a Hi-Flo edelbrock system and I am looking more specificaly for the upper runner to plenum gasket as the stock ones are smaller. Does anyone know where to get them? OR is there a kit that has all the hi flo's including the upper and lower in them?
I was looking at these but not sure if they are a hi flo or not (larger diameter bore)
http://www.summitracing.com/parts/ACC-74195G
Thanks in advance.
Old May 28, 2010 | 04:29 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: TPI Intake Gaskets
Those will work just fine. If they don't match the runner or plenum well, get out the x-acto knife and trim the excess away.
Old May 29, 2010 | 02:19 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
The ones you have selected are the high flow gaskets, you can tell by how little material there is showing in the image between the pairs of ports. The stock gaskets have quite a bit more meat. I am running these on my ported TPI and they work great. here is the link to the edelbrock ones
http://www.summitracing.com/parts/EDL-3866/
Old May 31, 2010 | 03:36 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Thanks guys. It looks like the accel ones wont work for my setup. On the fatory runners the left and right ones are different in how they seal against the lower. THe runners I have (edelbrock hi flo) the left and right side are the same. I need to use the replacement ones which are the ones that norcalz28 posted a link too.
Thanks again guys.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
