v6 air box same as v8 airbox?
Old May 29, 2010 | 01:26 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
does anyone know if the dual filter v6 camaro airbox assembly is the same as the v8 airbox assembly? im thinking no. but they use the same air filters so they might be? any help would be appreciated.
Old May 29, 2010 | 01:29 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: v6 air box same as v8 airbox?
The air filter set-ups will switch over and work. The only difference is that the v6 upper air filter piece has a threaded hole in it where the IAT sensor goes, but it will still work.
Old May 29, 2010 | 01:31 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
but i mean are the air passages the same size and the outlet on the top air box the same diamater? or is the v6 smaller for less air flow?
Old May 29, 2010 | 03:24 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
They are the same size. Right now my car has one off of a v6 on it tmeporarily.
Old May 29, 2010 | 09:40 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Is there something you're wanting to do that's different? If so, take a look at the TPI Airlid thread that's been resurected & working it's way around the past couple weeks. It's basically the Master's course in Air Box information. Nitro-Nicky
bad camaro RS
Aftermarket Product Review
Mar 24, 2001 07:10 PM
bad camaro RS
Mar 23, 2001 11:00 PM
bad camaro RS
Mar 20, 2001 12:33 AM
bad camaro RS
Mar 11, 2001 09:18 PM
bad camaro RS
Feb 27, 2001 05:29 PM
