7165 ecu?
Old May 31, 2010 | 11:39 PM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
7165 ecu?
i have a couple of questions for anyone willing to help me out; i have a 89 camaro tpi with a 7165 ecu and was wondering if this ecu is the correct one for my car , the motor was swapped out and it came with ecu and wire harness (which is no good) i was told the ecu was for a 350 tpi but not too sure. i had an electrician come over to help me out with a fuel problem and said the ecu was not correct for the car, is there any way to identify the ecu other than the 7165 it has printed on it?? all help is appreciated thanks in advance
Old Jun 1, 2010 | 03:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: 7165 ecu?
The 165' ecm fits both 305 and 350 tpi's from 86-89. The only difference between the 350 and 305 ones is the prom. Get the numbers of that and check what it belongs to.
Old Jun 3, 2010 | 04:28 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: 7165 ecu?
ECMs are the same it's the PROMs that are different. You need the PROM designed specifically for your engine.
Jake
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
tuningnewb
Sep 23, 2015 07:06 PM
