1991 z28 5.7 tpi
Car: 91 camaro Z28
Engine: 5.7 TPI
Transmission: 700R
1991 z28 5.7 tpi
My car started running like crap. It will die when I put it in gear if I dont give it gas during take off from park to drive. On going down the road it kind of shudders until I let off the gas. It shifts thru its gears and even chirps the tires a bit but its rough. I have put in new plugs and wires cap and rotor , coil ignition, module. I only use 93 octane gas in him. What do you think is going on?
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: 1991 z28 5.7 tpi
What is the timing at? Did it do this before you changed the plugs and wires, you may have crossed a wire so check the firing order. Does it get better once the car warms up?
Car: 91 camaro Z28
Engine: 5.7 TPI
Transmission: 700R
I did find that the header melted one spark plug wire. We changed it and performance is almost back where it should be but still a little shake as it gets to around 40 mph. It goes away if I really get into it hard and It runs smooth as can be 70 and 80 mph. engine temp doesnt seem to make a diff. It was running rich but seems ok now. any ideas?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Sanjay
Aug 12, 2015 03:41 PM
