Trouble starting. What could it be?
Old Jun 10, 2010 | 10:11 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
after my TBI to TPI swap I went to go start my car. she turns over and acts like its going to start, but then doesnt start unless i open the throttle a little, then it starts and runs. I had another throttle body so i took the TPS and IAC off the original throttle body but it on my other one, sprayed a little WD-40 in the IAC and put the throttle body on. It started and stayed running but the linkage is different on this throttle body and does not work with my throttle cable. I put the TPS and IAC on the original throttle body with WD-40 sprayed in the IAC and is started again. barely. its runnning rough not like it should. Is this a bad IAC. and should I replace it? also will the throttle body off a 95 Camaro Lt-1 350 work on an 89 TPI Plenum with the sensors?
Old Jun 11, 2010 | 01:15 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Trouble starting. What could it be?
does anyone have any ideaaa?
mrbird
Oct 20, 2015 03:43 AM
Thaney9
Oct 15, 2015 06:37 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
