tpi 350 motor question
Old Jun 13, 2010 | 05:29 PM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
i have a 87 iroc with a 350 in it the motor went and i found a motor out of an 87 trans am i bought the full motor with tpi for 300 dollars and when i had the two motors next to each other i notice on my motor the altenator was on the left and ac on the right but on my new motor its oppisite and i have mid length factory exhaust manifolds but the new motor has shorty exhaust manifolds any idea what motor it is i thought all tpi 350s were the same
Old Jun 14, 2010 | 09:30 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: tpi 350 motor question
Sounds like someone did a serpentine conversion on the 87 ta motor, it's a common upgrade.
But all your accessories will swap over if you wanted to do it, otherwise you would need to extend some wiring and find the proper hoses for the ac compressor to use the serp setup.
If you do swap be sure to swap the water pump too, as the serp one rotates in the other direction.
Old Jun 14, 2010 | 07:37 PM
Axle/Gears: stock
well can i just drop the motor in and hook up my radiator and just drive it or do i have to make mods and when i get i new belt what do i say i need it for since the belt system is different
Old Jun 14, 2010 | 08:00 PM
Yes you can drop the new motor in as is, but like i said you will need to modify some wiring to make it work. Also the plug for the alternator will need to be changed.
The belt from an 89 should fit.
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
