Fuel system woes
Old Jun 15, 2010 | 07:47 PM
timonator's Avatar
Fuel system woes
Now that I have my 91 Z running I realized that most of the time under load it sputters or bucks, and it surges at stoplights. I decided to tape my fuel pressure gauge to my windshield while I ran some errands today. The first thing is that at idle it's only like 31-32 psi. Under load or heavy acceleration it drops to between 25-27 psi. When I turn it off it doesn't hold enough pressure to register on the gauge, though there is some pressure there when I remove the gauge.
The car has a new fuel pump,new filter and all of the injectors ohm out above 16 and they are all clicking normally.
The one thing that concerns me is that the previous owner did the fuel pump replacement by cutting a hole in the floor,cutting all of the steel lines and reconnecting them with peices of rubber hose.
If anyone has any ideas why I'm losing pressure I'd love to hear them.
Thanks,Tim
Old Jun 15, 2010 | 07:51 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Fuel system woes
Thanks,Tim
pressure regulator...
Old Jun 15, 2010 | 07:56 PM
timonator's Avatar
It's not leaking. I've pulled it out twice to check it too. Could the spring go bad ?
Old Jun 15, 2010 | 08:01 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
you are going to have to test your fuel system then... search for fuel system test or leak down test...
Old Jun 17, 2010 | 12:23 PM
timonator's Avatar
Ok, after testing it, it turned out to be the fuel pump. The parts store I bought it from warrantied it for me. I just hope this one doesn't go bad too. Now it's throwing a code 32 and 33 so I have to figure that oyut now. The 32 is because I have the egr unhooked but the 33 I don't know why.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
