tpi 383 cam selection
Old Jun 19, 2010 | 01:57 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
So the motor popped '91Z and I'm looking at replacing it with a remanufactured crate 383 stroker motor built for a TPI application (roller motor, not flat tappet). The builder supplies a 205-205 450/450 lift 'computer friendly' cam and apparently produces 350-360 hp and 385-400 tq.
Is there a larger cam that anyone can recommend for this motor?
I will be running a TPIS big mouth intake with ported plenum and runners, headers and full exhaust, and eventually will be a 'full bolt-on' car with aluminum heads (I want to burn off some of the warrenty first). This car is currently backed with a 700r4 10 bolt 3:23's.
I'd like a cam which has at least a bit of a lope to it and makes more hp, something around 400hp (just a number I picked out of the air).
For me this car is a summer time driver that my wife occasionally drives, (she can handle a car with a bit of kick, she loves driving my IROC - when I let her, hehe). The engine builder does not have a problem with either changing the cam or if I supply one for them.
Thanks for your replies!
Old Jun 20, 2010 | 06:34 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: tpi 383 cam selection
For my build I went with the custom grind XFI cam from comp cams. It is 224/230 @.050 duration, with .565" .570" lift and 112 LSA. Or you can go with the XFI 268 which you don'h have to custom order. Either cam should meet your goals.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
