VATS
Old Jun 19, 2010 | 07:29 PM
mooch56's Avatar
Car: 89 Iroc-Z
VATS
I have an 89 IROC and the VATS keeps engaging. I tried bypassing the VATS by wiring the VATS power cable (purple) into the yellow ignition wire in the steering column. This allowed the motor to turn over but not start, because the VATS still engaged not allowing the injection system to fire so I had spark but no fuel. Then I put the wires back into the original position and now the VATS will not disengage, if anyone can help that would be great, or if you could give me some tips to disengage the VATS I would appreciate it.
Old Jun 19, 2010 | 07:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS
That is not bypassing VATS ; that is bypassing the starter enable relay.
You need a resistor on the wires under steering column to bypass VATS
https://www.thirdgen.org/vats_passkey_system
http://www.joestradingpost.com/vats/
Old Jun 20, 2010 | 10:47 AM
mooch56's Avatar
Car: 89 Iroc-Z
Re: VATS
Why do I need a resistor? Where does it go? What kind of resistor do I need? Thank you
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
