Help with my 305 TPI
Car: 1986 Iroc Z
Engine: 5.0 TPI
Hey I am hoping someone can help me...I have a 1986 Iroc Z with a 305 TPI. I recently bought a Edelbrock cam and lifter kit from summit racing to replace the stock one that was in it. Well I done everything by the book ( bought a Hanyes repair manual and followed the intructions) and now it will not start. I've checked all my vaccum lines and alll the little things I could think of that could possibly be wrong and I've got nothing. I tried turning the distributer for heck of it and I found out it will start up and run if you set the distirubter to on number 6 instead of number 1, but it doesn't have any power. I did call the tech line and the cam is suppose to work with my car. I don't know if I missed something, or if there is something about my car I don't know about. Any suggestions?
Here is the link to the cam: http://www.summitracing.com/parts/EDL-2102/
Car: 1986 Iroc Z
Engine: 5.0 TPI
Re: Help with my 305 TPI
Yes it will turn over. The fuel pressure is good and it is firing. That's why I'm so puzzled. I can't seem to figure out what the problem is. I was wondering if there was something small I might have over looked...or something special I need to do for this particular engine.
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
retime the motor...double check everything..
are you sure you got the cam gears lined up properly?
and becareful starting/stopping that cam...its hyd flat tappet, it HAS to be broken in properly, or the chances of wiping a cam lobe are severe.
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
yeah make sure that cam markings are lined up as well as the crank tdc, one other thing is that you purchased a flat tappet cam and lifter kit are you sure it wasn't a roller cam and not flat tappet
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
