Mildly retarded, could use some help
Old Jun 26, 2010 | 12:06 PM
Wolnam's Avatar
Car: 87 Camaro Sport Coupe/ 89 GTA
Engine: 2.8L V6/ 5.7L 350 TPI
I'm sure this has been posted but I wasn't able to find it. I'm buying a new engine for my GTA. The engine blurb states that a carb and intake must be added. I don't want to carb it , I want to put my existing TPI back on there. Is there any thing special I need to do or can I just bolt on all the TPI gear in place of the intake for the carb?
Like I said....I'm mildly retarded.
Old Jun 26, 2010 | 01:37 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Re: Mildly retarded, could use some help
yes you can. just depends on 86-below and 87 and up. 4 center intake bolt are at a diff. angle.
Old Jun 26, 2010 | 09:34 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Be sure to also check the cam specs. What might be a really neat lope at idle with a carb could make a TPI idle/run like sh_it. An LSA of 112 or greater and duration at .050 of less than 230 is a good general rule of thumb.
Old Jun 27, 2010 | 11:00 AM
Wolnam's Avatar
Cool. So I'll be swapping my parts from an 89 GTA the general rule of thumb that you pointed out sems to be what this engine is running. As far as cam specs...I have no idea, (I am mildly retarded), but if that were not correct, can you swap out a different cam?
Old Jun 27, 2010 | 11:07 AM
Wolnam's Avatar
And what does LSA stand for?
Old Jun 27, 2010 | 12:19 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
lobe seperation angle
Old Jun 27, 2010 | 09:46 PM
watajob's Avatar
Car: 92 T/A 'vert
Yes you can. Here's an article that explains the camshaft:
http://www.wallaceracing.com/cambasics.htm
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FueledSoul
Sep 30, 2015 09:18 PM
383backinblack
Sep 25, 2015 11:31 AM
ericjon262
Sep 11, 2015 06:07 PM
