setting time on 350 tpi
Old Jun 28, 2010 | 08:59 PM
bigtom68's Avatar
Car: 88 iroc-z
Engine: 5.7 tpi
im sure this has been asked before. im setting timing on a 88 350 tpi. i know its 6 degrees before tdc but does the car have to be in drive to do this. i think this may be an issue. im hoping this may fix a few problems im having. any input would be good
Old Jun 28, 2010 | 09:52 PM
puddingmmmmmmmm's Avatar
Car: 05 CTS-V
Re: setting time on 350 tpi
No, it doesn't have to be in drive. Leave it in park. And make sure you unplug the EST wire before you time it.
Old Jun 29, 2010 | 08:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
And don't forget to reconnect it after you have finished
Old Jul 7, 2010 | 09:56 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Reconnect the EST and clear codes by disconnecting the battery for 30 seconds.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
