common problem???
Old Jul 7, 2010 | 10:23 PM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
common problem???
driving down the feeder of 45 the other day, and the car usually stays at about a quarter on the temp guage.since im running no thermostat, she will only get up to 3/8ths in traffic......well she warmed up and the engine light came on, traffic started moving again and as the temp. got back down the engine light went out and never came back on. what does that mean........any help is much appreciated
Old Jul 7, 2010 | 10:34 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: common problem???
For starters you need to put a thermostat in you car. The problem is if the car dosnt get warmed up and stays in open loop operation this is not good. This is what I suspect happened. You have a problem that was not realized by your ECM until your car entered closed loop operation. The problem was detected and you check engine light was triggered. However one your temps droped back down again and you reverted back to open loop operation and the problem could no longer be detected. I would check for any stored codes and see what comes up and put a thermostat in the car and see how it does.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
