RHS HEADS!
Old Jul 12, 2010 | 09:34 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
RHS HEADS!
Whats the best head for a stock 1992 l98 350.. RHS the #12407 with there 1.9 1.5 valves or the 12410 2.02 1.6 ? ? Thanks, I'm looking to buy a pair!
Old Jul 13, 2010 | 01:20 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: RHS HEADS!
For stock, I would go 1.94 intake 1.50 exhaust and here's why.
The TPI system on our cars is not a high RPM screamer, and modified TPI (better base, runners, and FPR) has proven to be only a few hundred or so better than stock on the hp/tq curves. If you are simply bolting on a set of heads, nothing else (NOT reccomended BTW) I would go 1.94's.
If you are ultimately going to build the car, and this head swap is just all you can afford for now, go 2.02's. In the long run, there's no telling what induction system you will end up with (SR, MR, SuperRam, 1st fuel inj. etc.) and the 2.02's will then be able to be used more.
If it were me, I would get some headers and a better y-pipe AND a better catalytic converter before I bought heads. This will cost as much as heads and make some great power and sound. Later.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
