porting tpi runners and manifold,
Old Jul 16, 2010 | 07:45 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Im looking for a someone/place to port my accel runners and and manifold. i would like to siamiese my accel runners port them to 1.75 all the way through and gasket match them. I just ordered afr 180s and i would like to make sure that my tpi can breath to 5500 if possible with out welding. I didnt want to send them to extrude hone, i started one runner and I dont have the knowledge/experience to do it properly. If anyone is intersted please pm with prices.
His work as at the bottom
(Im not sure if this is the right forum but it said tpi porting.)
Old Jul 17, 2010 | 09:23 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Re: porting tpi runners and manifold,
anyone?
Old Jul 17, 2010 | 09:33 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Are the Accel runners the tube type? We have a place locally that has done porting for us. www.j-performance.com is his website. I'm just having trouble visualizing the Accel runners.
Old Jul 18, 2010 | 12:53 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
They look like the bottom of the edlebrocks they are tube type but they are cast .
Old Jul 18, 2010 | 10:06 AM
Abubaca's Avatar
I remember those accell's. I don't think they sell 'em anymore, but they were cast, and they did respond well to porting. Kinda like a full runner version of the super ram runners.
Old Jul 18, 2010 | 11:50 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
That's. What I hear so that's why I'm trying to port them
Old Jul 18, 2010 | 12:41 PM
Car: 1989 GTA
Engine: 369 TPI
OK, no problem then. A little welding and the runners can be siamesed if you want and/or opened up. If you have the money Dr. J in the link above can do it for you. I think he has two levels of porting the intake manifold itself. He did one Accel intake manifold recently that flowed around 330cfm. That will flat get it done and give the AFR180 heads all the air they can handle. If fact the heads will be the restriction.
Old Jul 18, 2010 | 03:20 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
you dont need to weld them for them to be siamesed they are cast I will take a picture
Old Jul 18, 2010 | 07:16 PM
Abubaca's Avatar
I think what he means by welding is that to fully siamese them, from plenum to manifold, you need to cut 'em open, port, and reweld them closed. Most people just get as far in as they can, but they're not fully siamesed.
....or I could be wrong.
Old Jul 18, 2010 | 10:25 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
ahhh yeah i dont want all that done to it just alittle bit more then the slps and with bigger ports
Old Jul 19, 2010 | 09:44 PM
Car: 1989 GTA
Engine: 369 TPI
What I was refering to was the "dip" between the runners. If I was going to siamese them I woud fill the "dip" with aluminum weld and then make the runners into one big oval for the siamese portion.
Old Jul 25, 2010 | 04:32 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
i thought about that but i actaully have slp's in my garage and i dont want to use them i like the look of the simi seperate runners I actually sent my manifold and runners off to a member on the covette forum he is down in southern ca. I will post pics as soon as i get them back.
Old Aug 2, 2010 | 01:53 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
If anyone is looking for. Porting services for there tpi. Pm me for his details
Old Oct 3, 2010 | 08:33 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
here is his work looks awesome i will post my manifold next and the plenum he did
Old Oct 3, 2010 | 08:34 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
the ones on the right are accel runners that he did and the lefts are slp runners
Old Oct 3, 2010 | 10:40 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Old Oct 4, 2010 | 12:50 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Thats some nice looking stuff you have. When do you think you will have it going?
Old Oct 4, 2010 | 03:51 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
well i still need to take the 305 block out of my camaro then get the fly wheel over to the machine shop so they can balance it. I have a pretty much stock rebuild on the bottom end with forged pistons and 10 to 1 compression.
Then I have bosch 3 24lb injectors with afr
xfi 268 cam
ported and siamesed runners
ported manifold
ported plenum
afr 180s
I am after the same amount hp as you are hopefully atleast
Old Oct 9, 2010 | 12:03 AM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
dspencer24, What gaskets are you using? I've started porting my SLP runners and was jus wondering what gasket you'll be using as my runners will ported like yours. Thanks
Old Oct 9, 2010 | 09:55 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Im using accel gaskets right now, for the top gaskets to the plemnum I just cut the middle out and rounded the edges to match. Ill find you a link for gaskets
Old Oct 9, 2010 | 09:58 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
http://www.jegs.com/i/Mr.+Gasket/720/146/10002/-1
im pretty sure these will work for you
Old Oct 25, 2010 | 11:57 AM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
How much did it cost for all that? Can he port stock runners or is it better buying slp and porting them? how much hp can you get by porting the intake, runners and phelum?
Old Nov 12, 2010 | 02:27 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Thanks for the words Don enjoy seeing builds like yours...look stock but run hard. Love sleepers.
(Never was good at taking those "glamour shots" lol)
Lots of neat builds going on here have to hang around, Camaros are my first love.
Pic of your base I dug up. Camera angle makes things look funky sometimes
Runners were siamesed 2 inches in if I remember right.
Looking forward to seeing what its putting down once running.
Nothing really to port there unless you cut them up. Cost/hp go aftermarket.
Old Nov 12, 2010 | 09:13 AM
ray jr's Avatar
ill be calling you on doing something like don did ..what runners do you like to port ?? as&m or accel ?? also is there a certain base you like ?
Old Nov 12, 2010 | 09:33 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
You cannot port as&m Or tpis. Only Edelbrock, accel and slp
Old Nov 12, 2010 | 09:37 AM
ray jr's Avatar
cool, i have the accel's.. just got to figure out what base to use ..
Old Nov 12, 2010 | 10:31 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
What base do you have
Old Nov 13, 2010 | 07:52 PM
mseven's Avatar
Car: y body
Engine: 396 sbc
Transmission: full manual 700r
Axle/Gears: 4.10:1
Ron does good work, looks great.
Old Nov 15, 2010 | 04:36 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
yeah im glad that I went with these i like the look personally i lot better then i do the slps that i have
Old Dec 16, 2010 | 04:13 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Can this guy port my tpi base for me? Let me know
Old Dec 16, 2010 | 06:29 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
lol ask him its cruisinartvette there is also 385in2005 and there is a couple of guys down in southern ca as well
Old Dec 16, 2010 | 07:29 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
is this a company or just a person doing this type of porting? Thanks
Old Dec 16, 2010 | 10:30 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
they are people lol
Old Dec 16, 2010 | 10:37 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
385in2005 is siamesing my runners alittle more and gasketmatching things cruisinart did a good job but he had alot of time in my runners i got my moneys worth.
Old Jan 13, 2011 | 12:32 AM
Bryce Mulvey's Avatar
We just finished welding up this TPI base and runners for the full competition porting package, Siamese runners and raise intake ports I'll keep you guys in the loop with some picture updates and flow numbers.....Allen,Don,Kevin I know you'll be watching
Old Jan 13, 2011 | 09:01 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
haha wow thats a lot of weld I am intersted to see a finshed product and see how nice you got that weld to look. I bet that super ram is gonna flow
Old Jan 13, 2011 | 09:26 AM
Axle/Gears: 4.11
Jeebus!LOL
Question...if you have a smog issue where you have to use the TPI or are just doing it to do it why not just use a miniram or an intake that already has a short runner?
Like to see the results, regardless. Looks like fun.
Tell us about the build its going on?
Old Jan 13, 2011 | 09:35 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
he is from cali so there is smog. I wish we could use a miniram out here leagally
Old Jan 13, 2011 | 12:18 PM
Car: 1989 GTA
Engine: 369 TPI
"why not just use a miniram or an intake that already has a short runner?"
One reason would be you can customize the total runner length to take advantage of "wave tuning". The 4th harmonic is worth 4%. The third harmonic worth 7% and the 2nd harmonic is worth 10%. If going for the 2nd harmonic you will use all three boost rpm ranges. The stock TPI uses the 3rd harmonic range for its boost. Most are well aware of the boost that creates. I might add that the LS1 type manifolds also use the 3rd harmonic wave. One more aspect is from I have read it is best to have the runner volume roughly equal to the volume of the cylinder. This helps in the added boost in flow from the kinetic energy from the ramming of the air mass into the cylinder. Again check out the LS1 type manifolds. If done right and with a good exhaust you can create up to 5 pounds of boost.
Bryce that looks real good. I am having my welder add some more weld beyond the fuel rail posts. When the machining and welding is done I will get my manifold over for you to do the porting.
Guys we have a car with a Super Ram recently done by Bryce and I do not believe to the extent of the above photos but the performance was well above average. Everyone attending the dyno session took notice. The results have been posted on this forum with Dyno Don the originator of the post.
Allen
Edit: Here is a link to the subject. An interesting read and talks about total runner volume.
http://www.speedtalk.com/forum/viewt...r+csa&start=15
Old Jan 13, 2011 | 03:57 PM
385IN2005's Avatar
Car: '97 GTP
Engine: 385 sbc, 3.8 Supercharged L67 V6
OK, so... you're raising the port toward the head end of the base? What about the rest of the port? Are you adding epoxy to the floor? I don't see a point in this.
Lingenfelter proved years ago that this has no benefit.
Old Jan 13, 2011 | 03:58 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That manifold will most likely flow in excess of 320 CFM and still over 300 with runners in place.
Old Jan 13, 2011 | 04:00 PM
  #42
Dyno Don's Avatar
I don't know what Lingenfelter did but we have proven it does have benefit.
Old Jan 13, 2011 | 04:12 PM
  #43
385IN2005's Avatar
Car: '97 GTP
320 cfm can be done without welding. Using a TPIS base.
Old Jan 13, 2011 | 04:17 PM
  #44
385IN2005's Avatar
Car: '97 GTP
The modification and testing Lingenfelter did was to a long tube TPI setup.
I have the article if anyone is interested.
Old Jan 13, 2011 | 05:05 PM
  #45
Axle/Gears: 4.11
Post it up so we can view it
Old Jan 13, 2011 | 05:12 PM
  #46
Guest
Guest
Posts: n/a
Using a TPIS base.
No point starting with anything from them if you're going to port it yourself. Save $100+ and buy it straight from Edelbrock.
Old Jan 13, 2011 | 05:14 PM
  #47
385IN2005's Avatar
Car: '97 GTP
Yes, true. Same base.
Old Jan 13, 2011 | 05:23 PM
  #48
Artisan's Avatar
Car: 89 Iroc
What do the factory bases flow after they have been ported?
Old Jan 13, 2011 | 05:31 PM
  #49
385IN2005's Avatar
Car: '97 GTP
Follow this link to see the article in question, Tuned Port Therapy.>>> https://www.thirdgen.org/forums/album.php?albumid=4181
Old Jan 13, 2011 | 05:40 PM
  #50
385IN2005's Avatar
Car: '97 GTP
It made some improvement when they swapped on large tube runners. They aren't clear as to if they used the large tubeS with the welded intake or just a ported intake. This article was written before there were any production large tube runners available. You should see the picture of the runners they made! Square tubes!!!
