Replacing the coolent temp sender. Questions.
Old Jul 20, 2010 | 06:16 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
I will be replacing the coolent temp sender on my L98 here shortly. Should i expect a lot of coolent to come out? Will i have to bleed any air out of the system after i replace it?
Old Jul 20, 2010 | 06:31 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Replacing the coolent temp sender. Questions.
The coolant will spill out at a pretty good clip, but if the coolant is cold and your quick you can do it on the fly, just put a drain pan under the car.
refill with a 50/50 mix, let the engine run to operating temp, if you need to add more after, add it to the reserve bottle.
Old Jul 20, 2010 | 06:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you drop the level down to water pump level with the radiator drain plug nothing will come out
Old Jul 20, 2010 | 08:05 PM
Abubaca's Avatar
I just did this tonight. And just to be clear, you're talking about the SENDER in the head, -For the gauge, right? The SENSOR for the ECM is in the manifold.
Engine was cold but I had a little pressure anyhow. Nothing dangerous, but it shot all over the frame rail ...I lost about a quart. ...nothing major. just a little refill.
Old Jul 20, 2010 | 10:29 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Helps some to pinch closed the hose from the rad. to the overflow tank, air locks the system and slows down the leakage some.
69 Six Pack
Oct 5, 2015 07:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
