350 tpi internal strength
Old Jul 20, 2010 | 08:24 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i want to take the intake system off the L98 and put a carb setup on, and i was wondering how high of an rpm can i operate at to be safe and drive daily and occasional strip use and i want to put a cam in also but im unsure of which one
Old Jul 20, 2010 | 10:36 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Re: 350 tpi internal strength
If your engine is relatively low milage, your valve springs are in good shape, a typical sbc is good to about 6000. If you aren't sure how good the bottom end is, then be careful.
There are two limiting factors, rod bolts and valve springs. Some people say a 350 can go higher than 6000. With good rod bolts (ARP) and good valvetrain you can go higher.
Old Jul 21, 2010 | 11:03 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok thanks alot and what cfm carb would be good for a L98 to rev that high quickly
Old Jul 22, 2010 | 08:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Use 85% for Volumetric Efficiency Of Engine
http://www.4secondsflat.com/Carb_CFM_Calculator.html
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
