How to set base timing on a 86 lb9
Old Jul 20, 2010 | 09:20 PM
motorworld's Avatar
Hello I have a 86 305 lb9 and I need to set the timing. I've read about unplugging the 4 wire plug but the motor won't run. I've read about unhooking the brown wire but do I have to remove it from the plug and rehook the other three wires. I am just trying to get a few thing straight before trying again. Thanks
Old Jul 20, 2010 | 09:27 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: How to set base timing on a 86 lb9
You have to have the distributor pluged in. Only disconnect the one brown wire connector.
Old Jul 21, 2010 | 07:11 PM
motorworld's Avatar
Thanks but is their a way to unplug just the brown wire? I see only the 4 wire plug. I don't want to cut up the harness on find out later the is a easy to do it. Thanks for the help
Old Jul 21, 2010 | 07:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Different wire; tan /blk
You are looking for single wire connector out of the main harness like this.
Vette position shown but yours the same connector.
Engine won't run with 4 wire dist connector unplugged
Old Jul 21, 2010 | 07:58 PM
motorworld's Avatar
Thank you, Thats just what I needed. I knew it was some thing dumb like that.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
