How to find out which TPI harness i have.
Old Jul 21, 2010 | 10:20 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I have to do a c100 pinout on my harness to match my 90 camaro. I have a TPI harness in my vehicle. It has cold start injector plug and it has mass air flow plug. That narrows it down to 86,87 or 88. Can someone tell me how i find out exactly what harness this is? thank you
Old Jul 21, 2010 | 11:37 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: How to find out which TPI harness i have.
Just a thought, it may be easier for you to convert your existing tbi harness for use with the tpi, you would have to add in the wires for the fuel injectors and the maf sensor, and maybe a few other miscellaneous things, there were not that many differences between the 2 harnesses, and then you wouldn't have to worry about the c100 and have a fully functional airbag. assuming, of course, you still have the tbi harness.
just found this in another thread might be worth looking at
https://www.thirdgen.org/forums/elec...ctor-info.html
Old Jul 21, 2010 | 02:46 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Thank you that thread helped alot. Can i find the tool to remove the pins anywhere or do I have to buy a special OEM tool? Since I already have this harness installed in my car im going to use the C100 diagrams to find out exactly what one i have and then repin it to work with my car. Ive done alot of research and i think i will be alright
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
