Anyone try bosch 4 injectors?
Old Jul 23, 2010 | 04:12 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Hey guys.. Im at the point where I can afford to finish getting my setup to optimal performance and Im lookin for injectors.
Ive been looking at both southbay and fic and seeing that there is a new bosch 4 design..they are pricey but seeing how many of you guys loved how wll the bosch 3 works..what more advantage is there in the bosch 4?
Wondering should I start off with the tried and true bosch 3's..or be one of the first to give the 4's a shot.
Opinions..good or bad let me know.
Old Jul 23, 2010 | 04:57 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Anyone try bosch 4 injectors?
I tried the Bosch 4,, the injector data is not readily available, so tuning the 92 was a little time consuming, Also you need wire adapters. I think the bosch 3 is a better choice for the above reason. I had alot of trouble with low Blm untill I got on a dyno and finally got it right. I see no difference
gta892000
Aug 11, 2019 11:16 AM
92-Formula
Dec 12, 2015 10:34 PM
lethaldomestics
Sep 21, 2015 01:18 PM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
