1991 firebird formula will not start
Old Jul 25, 2010 | 04:30 AM
kltenn's Avatar
Please help, my fourmula cut off while driving.I replaced the fuel pressure regulator,distributor module,distributor cap ,vats relay,ECM.I have 40 to 50 psi fuel pressure at the rail.It will crank over but not start unless you spray starting fluid in it.no codes in the ecm.will the ignition switch on the stering collum keep it from running or would it not even crank over if this is bad.The key resistance is good even tied the resistor trick.
Old Jul 26, 2010 | 02:26 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: 1991 firebird formula will not start
i have the say problem it will crank over but not start unless u spray starting fluid in it. it was starting up every day until one it started doing this,
Old Jul 26, 2010 | 03:42 AM
kltenn's Avatar
Yeah i been trying every thing nothing works still searching
Old Jul 26, 2010 | 11:00 PM
Irocwannabe's Avatar
Car: 90 formula 350
have you checked your oil pressure sensor?
Old Jul 27, 2010 | 03:17 AM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
i will today
Old Jul 28, 2010 | 02:19 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
put a noid light on it to test for injector pulse, a bad ignition module or a bad p/u coil can cause the injectors to not pulse.
jhawkeye
May 25, 2022 06:33 PM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Randomtask2
Aug 13, 2015 01:57 AM
