Lowering AFR
Old Jul 26, 2010 | 03:58 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
Lowering AFR
I have a 89 350 TPI. I keep reading about lowering your air to fuel ratio, especially when running nitrous, to say around 11.5.
I have a wideband 02 sensor so that I can track my AFR. When I try to lower my AFR so that it runs closer to 11, I cant get it away from the 14.6 baseline. I have an adustable fuel pressure regualtor, and I have put in larger fuel jets for my nitorus setup. Yet, even when I hit the nitrous, the AFR is still around 14.
Is this simply because without a chip tune, the AFR really cant be altered? Should I put in even larger fuel jets for the nitrous? I would like to run around 11.5 AFR when hitting nitrous.
Old Jul 27, 2010 | 12:13 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Lowering AFR
Probably just need bigger jets, I don't see the computer affecting anything when your at WOT.
Old Jul 28, 2010 | 04:07 PM
dv013003's Avatar
Engine: 5.7
Re: Lowering AFR
Is there any way to lower the AFR when simply running NA?
Bubbajones_ya
Jul 6, 2024 08:32 PM
Magman
Aug 2, 2016 08:32 PM
Antips16
Oct 30, 2015 06:42 PM
jbates346
Oct 21, 2015 01:50 PM
355tpipickup
Sep 13, 2015 11:35 PM
