88 5.7 tpi code 33 and 36
Old Jul 26, 2010 | 02:37 PM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
I can't figure out what's wrong with my car. The engine stalls and running rough when idleing. Somethimes it jerks while driving. It has code 36 and 33 and I changed the maf and the burnoff circuit and still nothing. Has this happend to anybody else?
Old Jul 26, 2010 | 04:36 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 88 5.7 tpi code 33 and 36
did you change the maf itself, or the relays?
A bad oil pressure switch could also set a code 33 (it interupts power to the maf power relay)
Old Jul 27, 2010 | 01:14 AM
Car: 88 IROC Z
Engine: 5.7
I chabged the maf and the burn off relay. ill replace the oil pressure switch n hope that's that's it. Thanks.
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
