TPI throttle body ?
Old Jul 23, 2010 | 03:33 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
TPI throttle body ?
i just did a smoke test on my car and i have a massive vacuum leak on both sides of my throttle shaft. is it possible to rebuild it? and is it something that can be done at home
Old Jul 27, 2010 | 01:31 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: TPI throttle body ?
Hello campbellerman!!
There are such things as throttle shaft bushings to fix the exact problem that your having, search the internet, they are out there.
You should be able to do this at home, as long as you take your time and plan ahead!!
Good luck!!
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
