82 Firebird with TPI350 starts and dies when hot
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi all,
My 1982 Firebird has developed a heat problem. The TPI/350 motor has been running great for 12 years with no major problems. But today after driving the car from Wilson to Cary NC, the engine died after a restart. I had stop at the MCD on the corner of High House and Cary Parkway, went into the store and got a drink. Upon returning to the Bird it crank right up and then died. I checked the oil, unplug and bypassed the Ignition box. The car crank, but would not start. I waited for about 20 minutes and then tried starting the car again and it ran. I stop the engine and reconnected the Ignition Box and restarted the car with not problems.
I drove the car back to Wilson, turn it off and went into my house. I came out about 20 min. later and started the car. Again it immediately died. I let the car cool down for about 20 minutes more and then it restarted and ran fine.
So whats is going on hear. I thinking the ignition module within the distributor is giving up when its hot or maybe it another problem, please help.
Thanks for your responses.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 82 Firebird with TPI350 starts and dies when hot
ohm test the fuel injectors when it is hot, sometimes they go out of spec when they're hot.
Hi again,
Please note: after I got the car to start today, it ran smooth. Accel. without any problems. Basicly no driveablity problems.
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
