Injectors
Old Aug 1, 2010 | 03:09 PM
BOOT77's Avatar
Injectors
Getting ready to bite the bullet and buy some injectors, car came with 19lb figure I'll need 24lb-45psi range or w/e. Already tried the cheapO route bought some used lt1 24lbs with 60k on em $30. Tried to clean em up http://www.youtube.com/watch?v=VFJlTfHyrUk worked great at 1st, several were spraying poorly or barley 2 were sticking open got em to stop sticking. $40 in cleaner total took several to find a kind that worked and $5 for the switch n syringe. So I decide to run some cleaner thru em one more time before install and now all are sticking open/closed at the start. So I don't trust my DIY cleaned injectors and figure I might as well just get a new set and cut my loses. Unless sticking and unsticking is common.
Anyways looking for some suggestions on injectors, don't need the best just want some decent injectors.
Old Aug 2, 2010 | 08:26 AM
Z28TT's Avatar
Car: 1992 25th Heritage Z28TT
Engine: 400ci Stealth TPI Twin 58mm Turbo
Transmission: Tremek TK-600
Axle/Gears: stock
Re: Injectors
I use TrickFlows
http://www.summitracing.com/parts/TFS-89072-1/
they have been great for sequential, but I wouldn't suggest such a large injector for a stock application, and mine isn't stock. Perhaps 24-30lbers
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
